- Apr 22, 2011
Bitspower Waterblocked, shunt modded with 5MO resistors for higher voltage, had it since Aug 2018 with no issues and always cooled by dedicated 360mm water loop keeping it in the high 40's in game most the time and peaks at about 56 at full bore. Have box and stock heatsinkfan.
1500 Shipped CONUS.
Need FP64 performance? No other consumer/prosumer card comes close for productivity.
Titan V: 7.450 TFLOPS at the advertised stock clocks of 1.45 Ghz, I run it at 2Ghz therefore performance should be substantially higher than stock clocks. https://www.techpowerup.com/gpu-specs/titan-v.c3051
3090: 556.0 GFLOPS aka TitanV is 13.4x faster. https://www.techpowerup.com/gpu-specs/geforce-rtx-3090.c3622
Titan RTX: 509.8 GFLOPS... TitanV 14.6x faster. https://www.techpowerup.com/gpu-specs/titan-rtx.c3311
Heatware: Stryker7314
https://www.heatware.com/u/63538/to
1500 Shipped CONUS.
