Prologue
Pics
Condition Report
- Prices do not include shipping and can be negotiated.
- My zip is 97333, Can meet up within a 2 hour driving radius.
- Willing to part out in bundles. PM me with what you want and we will work something out.
- z87/97 ITX mobo
- 4670k or better
- Black Ice GTS 240/Alphacool ST30
- GTX 670 waterblock
- GTX 970
- i7 4770k @4.5, Naked -$240.
- Maximus Vi- $140
- Crucial Ballistix 4x4gb -$120
Take Mobo/CPU/RAM for $475- 6950 flashed to 6970 shaders with a EK block -$75
- 750w Seasonic X-series (Gold) - $80
Case/Watercooling -$325 bundled- 650d - $120
- Swiftech MCP350 with XSPC Acryllic res top -$50
- Compression Fittings all the way around
- 1 Phobya 200mm Radiator [Push Pull Stock Corsair 200mm] -$50
- 1 PA120.1 Radiator [Gentle Typhoon-2150] -$50 w/ fans
- 1 Black Ice Xtreme 240mm Radiator [Gentle Typhoon-2150 x2 ] - $70 w/ fans
- 1 Silver kill coil
- All 120mm fans have silicone gasket
Take it all for $750 + half of shipping.
Pics
Condition Report
- In these pictures you can see a little bit of paint wear and where the drive cage sticks out bent a little bit.
- The integrated case fan controller was removed. Replacement can be found here: http://www.corsair.com/en-us/obsidian-series-650d-fan-controller-kit
- It is missing a pair of the rubber pads for the case feet.
- EK GPU block: some of the nickel wore off, doesnt affect the loop in any way shape or form.
- Loop will be flushed and drained before handing over to you.
- I kept all original packaging, hard drive cages, brackets, fan filters, and screws.
- Case was not modified in any way
