FS/T: dual 15" LCD, embedded pentium-m, Custom USB HD cases, more
First off, these are the trades I'm looking for:
- 12 volt laptop bricks, 5 amp or better, needs to fit a 5.5mmx2.5mm barrell connector
- Core 2 Duo mini-ITX board
NOT LOOKING TO BUY ANY OF THE ABOVE, ONLY WANT TO TRADE FOR THEM.
And the for sale stuff
prefer US only, some people seem to "forget" they're outside the country when negotiating prices with shipping
Prices do NOT include shipping unless noted
I ship USPS Priority for most locations, you want another method you can have it as long as you're paying shipping
I do combine shipping on multiple purchases
all items guaranteed alive on arrival, but otherwise sold as is
PayPal preferred
Heatware: http://www.heatware.com/eval.php?id=2914
Ebay under widefault
e-mail is [email protected]
Getting rid of my extras and stuff for projects I know I'll never got to. My lack of motivation is your gain!!! Will include driver disks and manuals if I have them. Trying to switch to Core2Duo for my projects, so these have to go.
Evalue/Avalue/BCM ECM-3710 3.5" Pentium-M Single Board Computer. This will come with 512MB DDR400 and a Pentium-M 1.6GHz Dothan(2MB cache). i855GME chipset, supports all 400MHz Pentium-M and Celeron-M CPUs. Tiny, 4" x 5.75". See the link for more info. Will come with all the stock cables(audio, serial, etc) and an ATX 12 volt vable for power, you'll need your own PSU and adapter for ATX mode power. I'll also throw in an Atheros 802.11b/g mini-PCI wireless card. Would make an excellent CarPC. Good for anywhere space is minimal.
Link: http://www.avalue.com.tw/products/ECM-3710.cfm
pics:
http://www.widefault.com/forsale/ecm37101.jpg
http://www.widefault.com/forsale/ecm37111.jpg
http://www.widefault.com/forsale/ecm37121.jpg
http://www.widefault.com/forsale/ecm37131.jpg
$250 shipped
Advantech PCM-9381, 600MHz(512KB cache) Celeron-M Single Board Computer. 3.5" size, 4" x 5.75" just like a 3.5" hard drive. Great start for a basic car PC, onboard sound, video, 4 USB ports, all the stuff a regular PC has but in a much smaller size. Pulls about 20 watts of power under a load, not so shabby. Will come with cables and driver CD, check the datasheet for a list but it includes the ATX adapter and audio cables. Check the link for all the details. Does not come with any memory, but if I can find some I'll probably toss some in for free. Yeah, free.
Link: http://www.advantech.com.tw/products/Model_Detail.asp?model_id=1-23A1CS&BU=ACG&PD=
$125 shipped
Aaeon GENE-4312-A11 Embedded Board. AMD geode GX@300MHz. 256MB PC100 included as well as a 4GB Hitachi Microdrive. All your basic PC needs, onboard audio, video, dual 10/100 ethernet, serial, parallel, IDE, and USB in a board the size of a 3.5" hard drive. Performance similar to a Pentium MMX@233MHz. Pulls about 15 watts of power and will run off of a 5 volt power source. Has a standard molex onboard for power hookup. Would make one hell of a compact firewall.
link: http://www.aaeon.com.tw/PD_Products...188EB1498B85_B0012382C79C4FB7AF_US_utf-8.html
$SOLD
Sampotech dual 15" LCD - Two 15", 1024x768 LCDs side-by-side in one casing. WOrks great. Two standard VGA inputs, comes with cables, PSU, manuals, etc. Light use, two bad pixels on the left side screen.
$200 shipped
Core 2 Duo T5600 - 1.86GHz, 667MHz bus, 2MB cache Merom. Works fine, replaced with a faster chip. OEM chip, SL9SG.
$125 shipped
Core 2 Duo T5200 - 1.6GHz, 533MHz bus, 2MB cache Merom. Cheap entry level chip, good replacement for a Core Solo or Celeron-M 4xx series.
$80 shipped
Pentium-M 770 - flakey as hell, sold as-is, not working properly. OEM, 2.13GHz, 2MB cache, 533MHz bus. Again, not working properly. Seems to have bad cache or something, won't boot all the way into Windows.
$30 shipped
Custom Radiation Meter USB 2.0 120GB Hard Drives
will start with a couple links for some previous ones I've built.
http://www.widefault.com/other/rad.htm
http://www.widefault.com/other/usbmeter.htm
http://www.widefault.com/other/worklog.htm
These are #4 and #5 that I've built for non-family and friends, not sure how many more I'll be building. These were built using genuine surplus Landers, Frary & Clark CDV-715(Model A) Radiation Detection Meters. Originally, those would have been used after a nuclear attack to monitor fallout levels. No where near as sensitive as a real geiger counter, if these could read any radiation you were probably in big trouble. These were all non-working with some electrical fault, I won't use a good one for a hard drive case.
Inside the case is a USB2.0 to IDE bridge board that supports up to 400GB drives. They MAY support 500GB, but it's not supported or guaranteed to work. There's also a full size 800mm fan for cooling. Fans are modded to run off 7 volts and are very quiet. Also has headers for activity and power indicators. These have been hooked to the guage on the meter. The needle shows activity, an LED in the guage shows power.
Hard drives are 120GB Seagate 7200.7s, retail drives with minor usage and quite a bit of warranty left. Pretty quiet, too.
Each drive will come with a power adapter and USB cable as well as a driver CD if the buyer wants one. These are not needed, the drives are compatible with just about anything that has a USB port.
Hard drives are covered by their own warranty, so I will guarantee the rest for one year. Void if drive is replaced, while it's possible to be changed it could result in damage to the cables if not done carefully. Of course, I've had one of these running for almost three years now with no problems even after about 7 drive changes.
Two available, asking $130(shipping included) each, $170 each shipped with a new retail 250GB Seagate drive.
eVGA Geforce 6600 256MB PCI-e. Have box, card, and DVI adapter. Works fine
$SOLD
ADS SimpleTouch USB2.0 3.5" hard drive case - Built-in autobackup with the included software. New in box.
$25 shipped
Metal Gear USB2.0 3.5" hard drive case - basic model, not even one LED. Works good, virtually new in box.
$20 shipped
60's Civil Defense CDV-715 Radiation Survey Meters - Have a few leftovers from building hard drive cases, now is your chance to get them for your very own. These all will have some kind of electrical issue, but are visually in very good shape for being 40+ years old. Have five left.
Drive Case Log: http://www.widefault.com/other/worklog.htm
$25 each shipped
Vintage 40's/50's Military Geiger Counter - Non-working, will need some help. Appears to be complete. Large and Green. Heavy, too. Was going to use it for a mod, but it's going to be too much work. Pics available.
Pics:
http://www.widefault.com/forsale/gc01.jpg
http://www.widefault.com/forsale/gc02.jpg
http://www.widefault.com/forsale/gc03.jpg
http://www.widefault.com/forsale/gc04.jpg
http://www.widefault.com/forsale/gc05.jpg
http://www.widefault.com/forsale/gc06.jpg
http://www.widefault.com/forsale/gc07.jpg
http://www.widefault.com/forsale/gc08.jpg
http://www.widefault.com/forsale/gc09.jpg
http://www.widefault.com/forsale/gc10.jpg
http://www.widefault.com/forsale/gc11.jpg
http://www.widefault.com/forsale/gc12.jpg
$40 shipped
20GB 2.5" laptop drive based mp3 player. "Songbank", not the latest or greatest but it works. Easily upgradeable to a larger drive, although 40GB may be the max. Comes with Songbank, carry case, power adapter, USB cable, manual, and driver/software CD. Doesn't come with the original ear buds, because they've been used and that's just gross to pass on to another person.
$75 shipped
X10 Lola Direct Connect Music System kit. X10 charges $49.99, much less from me. Forget the Lola software, though. This one works great with the ATI Remote Wonder software, and even better with Girder and the ATI/X10 plugins.
$15 shipped
OTHER STUFF - shipping not include
Intel 4 port Wireless router, 4 10/100, 802.11b - $15
PCB from one of the above, broken LEDs but works fine - $10
2x340MB IBM microdrives - $25 each, $40 for the pair
IDE 100MB Zip drive - $5
Maze4 copper-top for socket 478, 3/8" barbs - $25
256MB stick of registered DDR266, Infineon CL2 - $20
FPM DIMMs, 64MB and 128MB pulls from a PowerMac - $20
Stuff I won't ship, so don't ask. Pickup in the Green Bay area of Wisconsin
- Beige 4u rack case, good shape, shallow depth(under 20"). space for 2x5.25" and 2x3.5" drives. - $50
- White Inwin Q500N full tower case, cut out for a second PSU - $25
PayPal preferred
pics:
$250 shipped
$125 shipped
$SOLD
$200 shipped
$125 shipped
$80 shipped
$30 shipped
$SOLD
$25 shipped
$20 shipped
$25 each shipped
Pics:
$40 shipped
$75 shipped
$15 shipped
