FS/T: 17" LCD, Pentium-M combos, heatsinks, more
widefault
FS/T: LCDs, Merom HTPC, Core 2 Duo X7800, Mini-ITX combo, TV tuner, Flash Cards, more
First off, these are the trades I'm looking for:
- Slot load slim-DVD drive, burner preferred, need a couple
- 200GB+ SATA laptop drive, prefer 7200rpm
NOT LOOKING TO BUY ANY OF THE ABOVE, ONLY WANT TO TRADE FOR THEM.
And the for sale stuff
US only and Canada is NOT in the US
I ship USPS Priority for most locations, you want another method you can have it as long as you're paying shipping
I will combine shipping on multiple purchases
all items guaranteed alive on arrival, but otherwise sold as is
PayPal preferred
Heatware: http://www.heatware.com/eval.php?id=2914
Ebay under widefault
e-mail is [email protected]
C2D HTPC - Core 2 Duo T5200(Merom core 1.6Ghz, 2MB cache), 2GB G-Skill DDR2-667, AOpen i945GTm-VHL Micro-ATX board, dual ATI Theater 550 TV Tuners, NEC 16x DVD+/-RW, Zillion-n-1 flash card reader, Antec 300watt PSU, Silverstone MoDT heatsink, all in an Ahanix D-Vine MCE303 HTPC case with built-in VFD and Media Center compatible Remote Control. WOrks great, just needs a hard drive and an OS. Now the few "bad" things. No I/O plate, got the board as a system pull. I don't have the purple input dongles for the Tuner cards, but those are standard ATI and cheap on ebay if you need them. I do have a driver disc for one tuner, and the disc for the case's VFD.
Case: http://www.mce701.com/viewtopic.php?f=9&t=16
Board: http://usa.aopen.com/products_detail.aspx?Auno=2064
Tuner 1: http://ati.amd.com/products/tvwonderelite/index.html
Tuner 2: PCI version, not PCI-E, http://www.sapphiretech.com/en/products/multimedia_landing.php?gpid=114
$500 shipped
Core 2 Duo X7800 ES - QZXR, unlocked multipliers, 2.6GHz stock speed. Works fine, just make sure your system supports the Extreme Edition chips. Mine did not, so there was no benefit of this over a stock T7800. 800MHz bus, 4MB cache, you need a Santa Rosa Merom system.
$500 shipped
Celeron-M 1.3Ghz mini-ITX combo - Axiomtek/Elite i855 chipset mini-ITX board, Celeron-M 350J Dothan core with 1MB cache, 1GB DDR400. Good setup, was using it for a server until I upgraded to a Core 2 Duo setup.
Board: http://www.mini-box.com/3368G-Pentium-M-Celeron-M-MBD?sc=8&category=100
$120 shipped
17" Kogi L7EH-TA LCD monitor - 1280x1024, VGA input. Nice screen for the price, been running since 2003 without a problem. No dead/bad pixels I'm aware of. Comes with power brick and VGA cable.
$90 shipped
Matrix Orbital MX412 - USB 4x20 LCD with 2x5.25" 15 button bay insert. White on blue LCD. Works great, but has some slight scuffs on the edges of the insert. THE LCD IS PERFECT!!! Has hookups for fans, LEDs, and temp sensors, too. More features than I ever used.
Link: http://www.matrixorbital.com/product_info.php?pName=mx412&cName=lcd-mx4-series
$75 shipped
Avermedia M780 Combo PCI-E TV tuner - bare card, no driver disk or cables. Analog, OTA digital, and Clear QAM tuning. Works fine, bought to decode Clear QAM, but the local cableco doesn't broadcast any channels in unencrypted QAM. Already have another OTA tuner, so this one needs to go.
$70 shipped
3 x 4GB A-Data 266x cards, ~30MB/s read and write speeds. These do not work as a bootable drive, which is why I'm selling. Very fast cards
$50 each shipped, all three for $140 shipped
4 x 4GB PNY 266x cards, 46MB/s read, 34MB/s write. Fast, fast, fast, but also don't work as a bootable drive. Tw of these have never been out of their packaging.
$50 each shipped, all four for $210 shipped
6 x 4GB Generic "Samsung" OEM "280x" cards - Not 280x, not Samsung. They do work as bootable drives, but the best speed I got out of them was around 10MB/s, ~70x
$20 each shipped, all six for $90 shipped
Box of various Compact Flash cards
1 x 256MB Rosewill card, unknown speed
1 x 16MB Canon card, made by Sandisk, unknown speed
1 x 32MB Lexar 4x card
1 x 32MB RCA card, made by Sandisk, unknown speed
20 x 32MB OEM Samsung, unknown speed
2 x 340MB IBM Microdrives + PCMCIA CF adapter
$30 shipped for the bunch
Thermalright Ultra 90A for K8 - Have one of these, unused in box, missing the fan clips.
$20 shipped
Custom Radiation Meter USB 2.0 120GB Hard Drives
will start with a couple links for some previous ones I've built.
http://www.widefault.com/other/rad.htm
http://www.widefault.com/other/usbmeter.htm
http://www.widefault.com/other/worklog.htm
These are #4 and #5 that I've built for non-family and friends, not sure how many more I'll be building. These were built using genuine surplus Landers, Frary & Clark CDV-715(Model A) Radiation Detection Meters. Originally, those would have been used after a nuclear attack to monitor fallout levels. No where near as sensitive as a real geiger counter, if these could read any radiation you were probably in big trouble. These were all non-working with some electrical fault, I won't use a good one for a hard drive case.
Inside the case is a USB2.0 to IDE bridge board that supports up to 400GB drives. They MAY support 500GB, but it's not supported or guaranteed to work. There's also a full size 800mm fan for cooling. Fans are modded to run off 7 volts and are very quiet. Also has headers for activity and power indicators. These have been hooked to the guage on the meter. The needle shows activity, an LED in the guage shows power.
Hard drives are 120GB Seagate 7200.7s, retail drives with minor usage and quite a bit of warranty left. Pretty quiet, too.
Each drive will come with a power adapter and USB cable as well as a driver CD if the buyer wants one. These are not needed, the drives are compatible with just about anything that has a USB port.
Hard drives are covered by their own warranty, so I will guarantee the rest for one year. Void if drive is replaced, while it's possible to be changed it could result in damage to the cables if not done carefully. Of course, I've had one of these running for almost three years now with no problems even after about 7 drive changes.
Two available, asking $100(shipping included) each
ADS SimpleTouch USB2.0 3.5" hard drive case - Built-in autobackup with the included software. New in box.
$25 shipped
60's Civil Defense CDV-715 Radiation Survey Meters - Have a few leftovers from building hard drive cases, now is your chance to get them for your very own. These all will have some kind of electrical issue, but are visually in very good shape for being 40+ years old. Have five left.
Drive Case Log: http://www.widefault.com/other/worklog.htm
$25 each shipped
Vintage 50's Military Geiger Counter - Non-working, will need some help. Appears to be complete. Large and Green. Heavy, too. Was going to use it for a mod, but it's going to be too much work. Pics available.
Pics:
http://www.widefault.com/forsale/gc01.jpg
http://www.widefault.com/forsale/gc02.jpg
http://www.widefault.com/forsale/gc03.jpg
http://www.widefault.com/forsale/gc04.jpg
http://www.widefault.com/forsale/gc05.jpg
http://www.widefault.com/forsale/gc06.jpg
http://www.widefault.com/forsale/gc07.jpg
http://www.widefault.com/forsale/gc08.jpg
http://www.widefault.com/forsale/gc09.jpg
http://www.widefault.com/forsale/gc10.jpg
http://www.widefault.com/forsale/gc11.jpg
http://www.widefault.com/forsale/gc12.jpg
$40 shipped
20GB 2.5" laptop drive based mp3 player. "Songbank", not the latest or greatest but it works. Easily upgradeable to a larger drive, although 40GB may be the max. Comes with Songbank, carry case, power adapter, USB cable, manual, and driver/software CD. Doesn't come with the original ear buds, because they've been used and that's just gross to pass on to another person.
$75 shipped
Stuff I won't ship, so don't ask. Pickup in the Green Bay area of Wisconsin
- Beige 4u rack case, good shape, shallow depth(under 20"). space for 2x5.25" and 2x3.5" drives. - $30
- White Inwin Q500N full tower case, cut out for a second PSU - $FREE
... bought some stuff, ran out of money :mad: found a roll of duct tape and taped the end of my enclosure closed. Drive was 2cm too long. How does that happen???
these are flash drives right? pardon my ignorance
