This DVR set was used for a year or two and has collected dust for about a year. Has motion activated recording and all that fun stuff. Was not used very much and was pretty much maintenance free.
The unit is a Swann PRO 4000 and supports input for 4 cameras.
Everything is controlled with the front panel controls. I know I have one key for the drive and I will hopefully be able to find the second key.
It currently has a 120gb Maxtor installed
The back of the unit supports input for 4 cameras and 2 audio lines. As you can see it does have the BNC to RCA adapters so it will be fine if your camera uses either cable type.
3 cameras will also be included. One of them does not have a hood and has a few dents on the cable from mounting but works fine. The cameras do have their AC adapters
Each camera has power input, composite out, and audio out. However does not have IR for night vision although I do recall it being IR friendly for external IR lighting.
Also included is 2 coils of cable.. I do not remember the length but I did purchase them from Fry's for about $15 each.
SOLD
Heatware
http://www.heatware.com/eval.php?id=28463
SOLD
Heatware
