https://imgur.com/a/NXRFvBl
Have a couple things for sale:
[H]'s very own 3rd best mobo of all time, the P8Z77-I. Will come with the faceplate, upgraded the wifi chip some time back and a custom BIOS which really didn't add much honestly. Note: One of the RAM clips is missing but RAM is fully secure without it. Honestly only helpful when it comes to removing low profile ram. $Pending shippped
Samsung EVO 960 500GB (low use, replaced with a large drive)- $150
CDI: https://imgur.com/a/ZAopaBU
I have a 3770S that i used with the P8ZZ-i as an overpowered and underused HTPC - $Pending
If you're buying the motherboard and want a K chip, I can sell a 3770K i'm personally using instead for $Pending
2x8GB Corsair Vengeance Pro DDR3 2400 - $140
Heat:
https://www.heatware.com/u/1290
Heat:
