FS: Memory And HeatSink
morpheus6d9
2 - PU HEATSINK COPPER TUBING WITH FAN MADE BY COOLERMASTER USED IN HP SFF $15.00 EACH
4 - HP 4GB PC3-12800 DDR3-1600MHz $20.00
Manufacturer HP
Manufacturer Part # 698650-154
Memory Type DDR3 SDRAM
Capacity 4GB
Pins 240 Pin
Bus Type PC-12800
Error Correction Non-ECC
Cycle Time 1.5ns
Cas CL11
Data Transfer Rate 1600Mhz
Memory Clock 200Mhz
Rank Rank 1
Voltage 1.35
2 - IBM 2GB PC3-10600 DDR3-1333MHz $6.00
Manufacturer IBM
Manufacturer Part # 64Y6649
Capacity 2GB
Pins 240 Pin
Bus Type PC-10600
Cycle Time 1.5ns
Cas CL9
Data Transfer Rate 1333Mhz
Memory Clock 166Mhz
Rank Rank 2
Voltage 1.5
