I normally don't bump my FS thread often, but if it's listed in here, it's still available. Before you ask any questions, PLEASE READ MY THREAD.
Fine print: I don't generally put things on hold unless I have a good reason to, however, if two people contact me about something, I tend to give priority to the first person. If you are around Dallas, you can come pick up the items in person if you would like. Otherwise I'll ship it at your expense by a carrier of my choice (usually FedEx). I can ship internationally, however any prices with shipping included are for the US. If you find my prices unreasonable, I am always open to offers. I can upload higher resolution images if requested. Please do your research on all these items before buying them as if they aren't compatible with your stuff, I won't be held responsible for that. If you would like more pictures or have any questions, please PM me. Heatware.
Trades I'm interested in:
Network appliances: For listing purposes, each 1U appliance will be numbered starting at the top and descending (since there are 16 in total). If you want more details on a specific unit, PM me as I need to be brief or else the descriptions will go on forever.
#01 - Unavailable.
#02 - $99 - Short depth low power appliance running pfSense. Has a 1ghz VIA processor, 3 x 1gbit Intel NICs, at least 512mb of RAM and a 40gb hard drive.
#03 - Unavailable.
#04 - $115 - Same as #2, but with 5 x 1gbit Intel NICs and I believe more RAM.
#05 - Unavailable.
#06 - Unavailable.
#07 - $149 - 478 based appliance (2.4ghz + 512mb of RAM + 80gb drive I believe). 2 x 1gbit and 6 x 100mbit Intel NICs. Has VGA out and more ports on the back and a CF slot inside. Includes a full Windows Server 2003 + ISA server license. Shiny LCD displays things inside (and outside) the OS (and that's a knob/dial to the right that adds more functionality). Should have no problem running Linux.
#08 - $149 - Same as #7.
#09 - $125 - Same as #7, but with 2 x 1gb and 2 x 100mbit Intel NICs. Includes RSA SecurID software in lieu of ISA server.
#10 - $159 - 775 based appliance (specs generally better than the 478 based version). 2 x 1gbit Intel NICs. Has VGA out and more ports on the back and a CF slot inside. Includes a full Windows Server 2003 license along with RSA's SecurID software. Shiny LCD displays things inside (and outside) the OS (and that's a knob/dial to the right that adds more functionality). Should have no problem running Linux.
#11 - $159 - Same as #10.
#12 - Unavailable.
#13 - $159 - Same as #10, but with Websense software instead of SecurID.
#14 - $225 - Same as #10, but with ISA server instead of SecurID and 6 x 1gbit Intel NICs.
#15 - $225 - Same as #14.
#16 - Unavailable.
$149 shipped - Beyerdynamics DT770 Premium headphones. In excellent condition. Comes with pictured case, original box, manual, and 1/4" adapter. This is the 32 ohm version, so no amplifier required.
$499 shipped - Areca 1880i. Essentially new. All accessories are included. Newegg link.
$25 shipped - Alphacool NexXxos XP waterblock. Brand new and unused. Fits nearly anything AMD. For $5 more, I can include 2 brand new fittings (I have 1/4", 3/8", and 1/2" available; all pictured below).
$25 shipped - D-Tek FuZion waterblock. Was used to cool a dual Xeon system and is one of the best performing water blocks out there.
$28 shipped - Shuttle ICE genie heatsink and fan. This fits the Shuttle K45 and K48 KPC models. It's in excellent condition.
$14 shipped - 2gb stick of Patriot DDR3 1066mhz SO-DIMM. Works perfectly and is no longer needed due to an upgrade. Newegg link.
$150 shipped each - Hitachi Ultrastar 2TB drives with full disk encryption (model: HUA722020ALA331). These are the enterprise models that support FDE and are as good as it gets in SATA. Manufacturer datasheet.
$75 - MSI Hetis G31 barebone. Seldom used. In excellent condition. Newegg link.
$140 - Sony/HP FW900 24" widescreen CRT monitor. Arguably the best CRT ever produced. Manufacture date is November 2003. There is a small scratch in the anti-glare layer in the top left corner that you get used to very quickly (which will go away if you remove the anti-glare coating). VGA --> BNC cable will be included. PM me if you want more pictures or a detailed rundown on the condition. There is absolutely no way I will ship this thing, so you will have to come pick it up if you are in Dallas.
- Panasonic 7-14mm f/4 lens
- Panasonic GX1
- NEC EA231WMi monitors
- Uncommon Lian Li cases
- Unique/rare/high-end toys. Nothing specific in mind, but if you look through my previous FS threads to see the kind of hardware I normally deal with, that should give you a general idea.
#01 - Unavailable.
#03 - Unavailable.
#05 - Unavailable.
#06 - Unavailable.
#12 - Unavailable.
#16 - Unavailable.
