- Apr 15, 2009
This may be random but it's worth a shot.
I have 4 black display cases available. Items are located in my storage unit in Harrison, Ar 72601.
I will deliver them for free if you buy them all, but heres a catch. Only if your along my routes. Logistics will have to be worked out via PM.
If you live near the following Citys, I can deliver.
Akron, OH
Valdosta, GA
Dallas, TX
Springfield, Mo
Pretty much if you live along the major interstates from Harrison, ar to Any of the cities listed above, I can deliver. If in doubt, pm me your zip code and I'll see if its somewhere I can go off the beaten path for.
600$ Delivered. I move things for a living. I can do it cheaper and items will actually get to you in one piece vs sending freight.
If your pretty local to me, I will considering splitting the lot. 200$ Each delivered. Discounts for multiple.
No lighting, but has holes to add lighting if you wish.
Cases were used for approx 3 years in a vape shop I owned.
and brutal honestey, yes, the top is bowed on all of them as seen in the picture. This is normal over time of use. It does not effect the functionality of these cases at all though.
Akron, OH
Valdosta, GA
Dallas, TX
Springfield, Mo
