FS: Laptops
eqtitan
Heatware 113-0-0
1 remains
Dell Latitude E7250 - $180
  • i5 5300u 2.3ghz
  • 8GB
  • 12" 1366x766
  • 256gb msata
  • SDcard slot, 3 USB, 1 HDMI, mini DP, webcam, smart card slot
  • charger
  • Windows 10 pro license
  • German keyboard ($17.99 US replacement Ebay)
HP Elitebook 840R G4 | WARRANTY until 4/9/22 - $old to noxqzs[/QUOTE
  • i5-8350u Quad core 6mb cache
  • 32Gb Ram (2x 16Gb)
  • 192Gb Samsung M.2 2280 TLC
  • 14" 1920x1080 Touchscreen
  • Fingerprint scanner
  • Bang & Olufsen, dual stereo speakers, integrated multi array microphone
  • 1 USB 3.1 Type-C™; 2 USB 3.1 Gen 1 (1 charging); 1 DisplayPort™ 1.2; 1 VGA; 1 RJ-45; 1 docking connector; 1 headphone/microphone combo; 1 AC power; 1 Smartcard reader
  • Bluetooth 4.2
  • Backlit keyboard
  • Webcam
  • Windows 10 Pro license in BIOS
  • Charger
Dell Latitude E5570 - $old to JustAPerson
  • i5 6300u 2.4ghz
  • 8GB
  • 15.6" 1920x1080
  • 256gb m.2
  • SDcard slot, 3 USB, 1 HDMI, 1 VGA, webcam, smart card slot
  • charger
  • needs battery ($34.99 OEM replacement Ebay)
Really need to sell theses (but not desperate) so I can get a motorcycle!
quick question,
Does the sim card take Verizon wireless?
I tried to research,couldn't get an answer.
Thanks.
quick question,
Thanks.
I'm not sure but I would suspect that if your carrier uses SIM cards it should work, that being said i found this:
If the WWAN card is HP XMM™ 7360 LTE-Advance WWAN than it will supports Verizon. See here : https://www8.hp.com/h20195/v2/getpdf.aspx/c04123334.pdf Only two cards are supporting the 840r G4 with the one listed here as the stock option I'll check when I get home.
quick question,
Thanks.
I got done chatting with HP support and they confirmed that this laptop does not have a WWAN card installed. Updated OP
What kinda bike?
Depends on the funds I can raise I suppose. My first bike was a 2015 Honda CB500F, and I've been looking at the CB1000 1990-2014, Yamaha bolt, Kawasaki vulcan s but honestly whatever I can find in my price range that runs but may not look the best. It's more about the ride than the aesthetic. Thank you for asking
