Fujitsu S6210 laptop / notebook --- $475 shipped OBO
Specs:
Intel Pentium M 1.6gHz 1M Cache
Centrino Mobile Technology
1280 mb DDR2 ram (1.280gb --> 1gb + 256mb sticks)
13.3" Crystal View XGA LCD (no dead pixels)
40GB hard disk
Toshiba SD-2512 24X DVD/CDRW
ACPI ac battery button fan processor thermal
ACPI hotplug capability
ALPS touchpad
3 USB 2.0 ports Intel 82801DB EHCI
Broadcom 4400 10/100 Ethernet (RJ45)
Intel Pro Wireless 2200bg 801.11b, 802.11g
IEEE 1394 Firewire
S-Video out
Memory Stick / SD Flash card slot
Cardbus (yenta) slot
Windows XP Home pre-installed
There are two issues w/ the laptop:
1. The backlight does not work at the moment. I'm not sure exactly what the problem is; it's most likely the backlight bulb or inverter. Anyone that's experienced working w/ laptops probably find it very easy to fix. I'm not exactly sure on the price of replacement parts, but I don't think they're that expensive.
2. The ac adapter is finicky. Sometimes it works and sometimes you have to jiggle the cord a little, but it does work. A replacement from fujitsu is around $50.
There are some scratches and dings on the case but otherwise everything works fine except for the backlight as mentioned earlier. The battery is included and also keeps a pretty good charge.
Here's a link to a laptop of the same model (sorry I don't have a digital camera to take pics at the moment): http://www.notebookforums.com/thread31833.html
I have Heatware under FALLENCOW.
Specs:
40GB hard disk
ALPS touchpad
IEEE 1394 Firewire
S-Video out
