TeleFragger
- Nov 10, 2005
Payment via PayPal only
OBO accepted...
I bought stuff to make a freenas box without checking into it. I used some parts that were free... from friends
but drives i bought without understanding red drives were for nas...
i bought wd blacks as I figured high speed desktop drives...
oh well barely used. i have drive run times from an app with serial numbers...
so ill take trades for stuff in the list
so the parts i would take for trade do not have to be this exact but guy recommended these for freenas
System Board: Supermicro X9SRL-F Motherboard Socket LGA2011 System Board
Memory: SAMSUNG 16GB Samsung PC3L-12800R DDR3L 1600 Registered ECC Server Memory
CPU Fan: Dynatron R27 Side Fan CPU Cooler 3U for Intel Socket LGA2011 (Narrow ILM)
CPU: Intel Xeon E5-2630 v2 SR1AM 2.6GHz 15MB 7.2GT/s Hex Core Server CPU Processor
CPU: INTEL XEON E5-2680V2 10 CORE 2.80 GHz 25M 8 GT/s 115W PROCESSOR (SR1A6)
Drive Controller: SAS PCI-E 3.0 HBA LSI 9207-8i P20 IT Mode for ZFS FreeNAS
Data Drive Cables: Mini SAS to 4-SATA SFF-8087 Multi-Lane Forward Breakout Internal Cable
i7-2600 - Amazon has one used for $119... take $80 obo?
(take $500 plus shipping)
Case - Antec 900
P/S - corsair hx620w
Mobo - Gigabyte GA-Z170XP-SLI - https://www.gigabyte.com/Motherboard/GA-Z170XP-SLI-rev-10#ov
CPU - intel i5-6600k
Heat Sink - Cooler Master
Memory - 4 x 8gb 1Rx8 PC4-2133P-UA1-10
hd - 120gb samsung ssd. Just installed Win10 Pro and verified I did not enter key and it is registered...
as now O/S registers to Mobo...
(freenas mod helped me as i was saying what i was going to use as system above but he said sell it all
and this is what he said)
You have four memory modules that should be worth $70 each, a system board that should be worth $65,
and a processor that should be worth $175. That should bring you around $520, if you sell them
for the going rate on eBay.
so for $500 im $20 less than he says plus throwing in case/ps/win10 and 120gb ssd
( take $250 )
case - Kolar - unknown model ($40?)
Motherboard Jetway nf9e-q77 ($250) https://www.jetwaycomputer.com/NF9E.html
Ram 2x4gb pc1333 ($46)
CPU - i3-3220T
Drives - 80gb intel ssd ($20)
........seagate 500gb ($30)
was working but wife threw out the power supply plug. will need a new one and sold as is
(take $80 each) WD Black 2TB Performance Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD2003FZEX
https://www.amazon.com/dp/B00FJRS628/ref=twister_B07M946KTW?_encoding=UTF8&th=1
Model,WDC WD2003FZEX-00Z4SA0,,,,
Serial Number,WD-WMC160188765,,,,
Power-On Hours (POH),"6,549",92,92,0,Ok
Serial Number,WD-WMC160127720,,,,
Power-On Hours (POH),"29,369",60,60,0,Ok
Serial Number,WD-WMC5C0D22YHV,,,,
Power-On Hours (POH),"22,895",69,69,0,Ok
Serial Number,WD-WMC5C0D5H6X5,,,,
Power-On Hours (POH),"7,360",90,90,0,Ok
(take $50 each) WD Black 1TB Performance Desktop Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD1003FZEX
https://www.amazon.com/dp/B00FJRS6FU/ref=twister_B07M946KTW?_encoding=UTF8&psc=1
Model,WDC WD1002FAEX-00Z3A0,,,,
Serial Number,WD-WCATRA981452,,,,
Power-On Hours (POH),"13,906",81,81,0,Ok
Serial Number,WD-WCATRA976422,,,,
Power-On Hours (POH),"13,800",82,82,0,Ok
Serial Number,WD-WCATRA973134,,,,
Power-On Hours (POH),"26,017",65,65,0,Ok
Serial Number,WD-WCATRA971035,,,,
Power-On Hours (POH),"26,056",65,65,0,Ok
Serial Number,WD-WCATRA966224,,,,
Power-On Hours (POH),"8,233",89,89,0,Ok
Serial Number,WD-WCATRA971142,,,,
Power-On Hours (POH),"9,733",87,87,0,Ok
thanks for looking
OBO accepted...
Case - Antec 900
( take $250 )
CPU - i3-3220T
thanks for looking
