Hello! I have way too much stuff I don't use lying around, and I could use some extra cash. All of the stuff is OBO, so feel free to contact me if you are interested in something. Shipping is included unless stated otherwise. Enjoy! Bump if you're feeling nice
[size=+1]
DFI nForce4 LanParty Ultra-D - $80
I may be missing some of the cables, etc. that came with as well as the original box, but most everything you need for it should be there. This is a fantastic motherboard and it worked so well for me when I had my s939 setup.
LG Flatron L1720P 17" LCD Monitor - $50 + Shipping
Good looking 17" monitor. No problems with it at all. Comes in original box.
Pentium 4 3.0GHz Socket 478 CPU - $40
This processor came with a Shuttle PC that I bought a few years ago. It hasn't been overclocked because the Shuttle motherboard is complete garbage, so I'm not sure how it OCs. However, it still runs really well. I have an XP-90 cooler that fits s478, which is posted below, that I can bundle with it if you would like.
Thermalright XP-90 CPU Cooler - $15
I used this with my 939 setup and then moved it to the 478 Intel listed above. Kept everything running really cool. I only have the 478 mounting system, so keep that in mind. The 90mm fan is included. It's pretty quiet and fast.
ATI Radeon 9550 - $20
Another part from the Shuttle PC. The only games I really ran on it were CS:S and WoW, and it played both of those at fairly good settings. Inexpensive AGP card for a cheaper box.
Laing D5 Pump - SOLD
Black Ice Pro II Dual-120mm Radiator - SOLD
DangerDen TDX CPU Block - $25
I have no idea what mounting equipment or top I have on this. I'll update if I figure it out, but DD sells the tops and mounting kits for cheap.
DangerDen Maze4 GPU Block - $20
Fits many of the older cards which don't necessarily need RAM cooling. I don't think I have any of the mounting kit for this either. DD also sells the hold-down kit for this block.
Eheim 1250 Water Pump - $40
This pump is a behemoth in many ways. It is a really powerful pump, good for systems with a lot of blocks. However it's also a really big pump. AC powered, as well.
[/size]
Thank you for looking! I may be adding things as I find them, so check back often!
Heat: alex41290
[size=+1]
[/size]
Heat: alex41290
