Hey fellas,
I'm moving one of my desktop rigs into my office at work, and since I want it to be as low maintenance as possible I am parting out its watercooling system.
Up for sale today is the radiator component, a Danger Den Cooling Cube. Just google that name to find some images. As the name suggests it is a square shaped radiator, and allows for the possiblity of mounting 120 size fans at both the front at back. For example I had it mounted againt the top of my tower, so that one fan was attacked to a blowhole / grill, the cube to it, and another fan on the opposite side of the cube pushing air through. It worked quite well.
Its nozzles accept 3/8" sized tubing. If you want to use a larger size you can certainly make or buy a little converter. I've flushed the radiator for several hours with a variety of different sterlizing and cleaning chemicals, so it is great condition!
So sum it up:
Danger Den Cube Radiator - 3/8" fittings - support for dual 120 fans - great condition
$18 OBO
edit: For references, most of which are from [H]ardFourms check out my Heat profile, MrXerxes
So sum it up:
$18 OBO
