FS: Dancase 8700k 32GB DDR4 SFF ITX everything but GPU
branana
8700k LM delidded
Asete 645LT AIO cooler with Noctua 92mm fan
Asus ROG Maximus Impact VIII Z170 ITX board
EVGA RTX 3070 XC3 SOLD
Dancase A4-SFX v3
2x16GB 3000mhz crucial ballistix
Samsung 860 500GB SSD
Corsair SF600 PSU Plat
I'm selling the above full build SFF gaming computer to make room for new toys. The board is Z170 bios modded, but it has more than enough power delivery, it is a ROG Maximus board afterall.
I will sell the full build shipped insured for $760.
Some part out combo prices
motherboard+cpu
260​
motherboard+cpu+ram
390​
case+cooler
270​
Description:
There are no running issues with this build. Here are what you need to know:
* Bios on the motherboard was modded to work with 8700k. It works perfectly for me. I could run 5.1ghz on water (obviously not in this SFF build). Updating to a non-modified BIOS will brick the board unless you also have a 6000 or 7000 series Intel CPU handy. Expert users only.
* See my picture, the fans on the GPU will rub without the red 3M tape acting as padding.
* EVERYTHING is a tight fit. If you plan to work on it know that it will take time to route the tubing and power cables JUST RIGHT. I'm not responsible for you disassembling it then severing tubing or wiring during re-assembly.
* Here are the other 8th/9th gen CPUs this board currently supports via BIOS mod: G5400, G5400T, G5420 (SR3XA), G5420T, i3-9100F (SRF6N), i5-8400, i5-8400T, i5-8500, i5-8500T, i5-8600, i5-8600T, i5-8600K, i5-9400 (SR3X5), i5-9400T, i5-9400F (SRF6M), i5-9500, i5-9500T, i5-9500F (SRF6Q), i5-9600, i5-9600T, i7-8700, i7-8700T, i7-8700K, i7-8086K
It is after all a 7.2L powerful gaming build so there are thermal compromises. Personally I only ran the 8700k at stock because I only played competitive games on it.
Bump, I have the exact same setup as my media PC, I also have the pads on my 3070 so it doesn't contact the Dancase side panel.
