I'm considering parting with my watercooling setup. The waterblock is a danger den TDX with tops for socket A/462, 754, 940, 939 and AM2. The radiator is a newly-bought heatercore designed to work with a 1977 pontiac bonneville (designed to use two 120mm fans), and the pump is 11.7gpm capacity (would come submerged in a reservoir). The whole setup has fit in both cases in which I've had it installed--I would provide installation advice to anyone interested.
The setup sold all together is probably worth about $130. Heat rejection capacity of the unit with the two 120mm fans running on 12V is likely in the 150W range, more than enough to handle the CPU as well as a couple of video cards and/or a northbridge.
Top of the case, from the side: Supply and return for water into the rad are on the right.
Bottom right of the case, below the hard drives: view submerged pump and reservoir. The res is watertight save for the 1/4" hole in the top for the AC power cord. Looks like the res is a touch dusty--water is not really discolored.
Waterblock. Line on the right comes from pump, line comes out towards left and travels up outside the case to the res.
From front of the case, you can see the supply and return for res. Silicone is there for insurance against leaks.
If you'd prefer, I can send the case and 12cm fans/grills with it. We can always negotiate a price. $130 for pump, reservoir, block with two brass tops (Socket A and 754/939/940/AM2) and radiator is negotiable. Shipping will be calculated at time of deal-making.
Post questions and contact me if you're interested.
Thanks,
jkpq45
Thanks,
jkpq45
