UPDATED: 4 more
For Sale I have 5 Cable Signal Amplifiers. It amplifies your signal by 15 dB. I will also include two RG6 quad shield jumpers. One for the power and one to connect back to the splitters where you will be installing it.
This is NOT the stuff you get at the stores such as radio shack and Home depot. This is the real stuff the cable companies use. This will not cause any ingress, and has full range of mhz 54 - 1000 and return path 5-42. Pictures available upon request. I do prewires for houses being built and am stopping for winter. I purchase them in a full box of 10 for over $300.
They look like a 2 way splitter except one leg is INput, one leg is OUtput, and one leg is power.
Please note: You can only safely amp your tv signal. Your internet is sensitive on a high and low scale. Too much signal is as bad as too low. If you buy this and you have cable internet make sure you amp everything but the modem line. Otherwise your modem may go offline, or be unstable due to too much signal. However, if you KNOW your modem line is way short you CAN amp the line as this amp has a return path. Just check the modems diagnostic page after install to check the signal levels.
Cost: $25 shipped
Quantity Remaining: 4
1 sold,shipped, and DELIVERED to setscrew
1 sold,shipped, and DELIVERED to Awol
1 sold,shipped, and DELIVERED to 2FAST4U
1 sold and shipped to movax
1 sold,shipped, and DELIVERED to jkerr2
Payment via paypal only. Non cc if possible.
HEAT: panalogic
Cost: $25 shipped
HEAT: panalogic
