BLhealthy4life
- Mar 21, 2006
For Sale:
SOLD!!
1. 6GB Triple Channel OCZ Platinum 1866
Brand OCZ
Series Platinum
Model OCZ3P1866C9LV6GK
Type 240-Pin DDR3 SDRAM
Tech Spec
Capacity 6GB (3 x 2GB)
Speed DDR3 1866 (PC3 15000)
Cas Latency 9
Timing 9-9-9-28
Multi-channel Kit Triple Channel Kit
Heat Spreader Yes
Features Designed specifically for the Intel X58 chipset / Core i7
Recommend Use High Performance or Gaming Memory
Manufacturer Warranty
Parts Lifetime limited
Labor Lifetime limited
[/IMG]
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227380
Asking $100 shipped <- SOLD
Heat is BLHealthy4life
Thanks
SOLD!!
Brand OCZ
Series Platinum
Tech Spec
Cas Latency 9
Timing 9-9-9-28
Heat Spreader Yes
Thanks
