Fresh back (as in just arrived this afternoon) from Crucial RMA department. all are sealed but ONE stick that i removed to inspect for visuals and will be memtesting this stick later tonight to determine its worthiness.
sticks are as in title...
4x 1GB PC8500 DDR2 1066 5-5-5-15-2T 2.0v w/ LED - NIB fresh from RMA
Looking for 50 plus shipping for all 4 sticks...
heat: fubar569
ebay: lipper540
EDIT: ends in 8FE5 - single sided sticks...awaiting confirmation of my testing but if this is the same 2.2v stuff i sent in the first time i'm gonna rip crucial apart...and i will subsequently lock the thread because the 2.2v spec is what killed the first batch...and i do not want any of you to have the nightmare i went through trying to get them replaced...
EDITEDIT: - memtested a single stick of it at 5-5-5-18-2T (autodetect) at 1066mhz and 2.0v and it passed. i am using it right now. No errors existed through 3.5 passes and it's been in the system for a few hours now and no issues are apparent. I pulled the EPP and the voltage for 1066 is still spec'd at 2.2v but it is running fine at 2.0...I will be emailing crucial about this...
heat: fubar569
ebay: lipper540
