These monitors are the best I have ever used, and made a GREAT triple-monitor setup on my rather large desk! They are all but new with hardly even a scratch on them, and the date codes are all mid to late 2003. They are the current model Sun sells with new systems, and can be seen on Sun's website here (and Sun sells them for $900 BEFORE shipping). You quite simply won't find a better monitor for under $1k anywhere.
Specs:
21" FD Trinitron® (True Flat Screen) Tube, 19.8" Viewable
0.24mm Dot Pitch
2048 x 1536 @ 75Hz Maximum Resolution (1600x1200 @ 100Hz is TEH WIN)
Timing Data Table (TDT) - 28 modes, User-Adjustable - 15 settings
Dual VGA Video inputs (Or remove the cable adapter to connect to a Sun workstation with 13w3)
Dimensions (WxHxD): 19.72x 20 x 19.88
These are fully PC frequency compatible. They will work with any normal PC or Mac computer with a VGA port!
Pictures:
Asking $220 each shipped, or $150 each for local pickup in Raleigh, NC
I have three availible, and I can negotiate a bit if you want a pair or the full tri-monitor setup (and belive me, you DO)
Specs:
0.24mm Dot Pitch
Pictures:
