This is a 3700+ DTR, socket 754. No IHS, no HS/F : updateSOLD
Will sell for $135, this includes shippings (standard UPS)
I do not have heat, so will be happy to ship first, assuming YOU have good feedback.
/edit I should add, since there is no IHS, You will need to use an aftermarket cooler that can screw down directly onto the mobo and hit the core. I will not be responsible if you fry this because you used a stock HS/F and stock HS/F connector.
