FS: 350 Lumen Projector
A friend of mine is selling his projector. Specs can be found at http://www.buyplusdirect.com/site/vp800specs.html
His does not have the remote. Does come with a bag. Here are specs:
Projection System - LCD
Resolution - 800 x 600 SVGA, with XGA Compression
Brightness - 350 ANSI Lumens
Contrast Ratio - 150:1 Full On/Off
Weight - 9.3lbs, 4.2kg
Power - Built-In Universal Power Supply
Data Compatibility - VGA, SVGA, XGA, and Macintosh
Video Compatibility - Auto-Detection of NTSC, PAL, & SECAM
Elevation/Keystone - Elevates image up to 20 degrees.
Variable keystone correction up to 25 degrees.
Display Modes - Upside-down and reverse imaging for ceiling mount and rear projection.
Color 16.7 Million Colors
Picture 6.4' Active Matrix Color TFT LCD
Sound Two 3-Watt Speakers
Lightsource 14 x 11 x 5", 35 x 28 x 13cm,
with integral carrying handle
Layout Parallel footprint for minimum on-table impact.
Looking for $450 + shipping.
FF5
