FS: (2) AquaXtreme 50Z Pumps
They are in great condition and run great. They havent been used for very long.
Im asking $55 each plus shipping.
Specs:
Nominal voltage - 12 V DC
Nominal power - 9 W
Motor type - Brushless, microprocessor controlled
Maximum head - 3.2 M - 10.5 FT
Maximum discharge - 700 L/HR - 185 GPH
Rotational speed - 3000 RPM
Connection size - ½" Barbed
Electrical connector - Molex 4 pin
Weight - 1.4 Lb (650 gr)
Motor casing material - Aluminum
Insulation - E Class
This is a Great pump for a system with a smaller rad because of the crazy low heat dump. However, it is still powerful enough for a big rad. It will give almost identical temps to a D5 according to Cathar's pump testing. And when overvolted to 13.8 volts, this is easily the best performing DC pump below $200.
Specs:
Nominal power - 9 W
