Frustration Need Help Fast get ready to read
Suki243
Hello, well this is my frustrating problem, well today i was cleaning out my room and i found these screws that went in the inside my case to keep the front bezel on, so i put the first screw in and booted it up and it was fine. I could get past the password screen with both my mouse and keyboard working.
Then i turned off the comp to put the rest in, this time i took out all of the cords and tilted the comp vertically to put in the last 3. (Last time i didn't totally flip the case vertically just tilted it) Well his time when i tried to boot it up my mouse and keyboard weren't responding at the password screen i said to my self its ok this is happening becuase i pulled out the mouse and keyboard cords, (they are wireless) so i tried really hard to reconnect the wireless signal but it wasn't working.
So i find this wired keyboard, and that didn't work i'm panicing now and so then i remembered that when i disconnected the wire to the front of the bezel for the temp display and stuff. So i thought i might've plugged it in backwards so i tried to turn it the right way but the comp would turn on for 10 seconds then shut off so i thought to myself no so i turned it around and plugged it the right way and it works till the password screen again.
Now i'm getting really frustrated, so now i go into the bios and the keyboard works i go bak into the password screen and it stops working, but then i remembered that after i turned that cord that goes into the front bezel it told me that it would reset bios because overclocking failed but i never overclocked but i have seen this before so i just continue.
Now i need help from you guys and i'm also thinking of taking this to fry's and asking them to repair but they are expensive, please answer
well after the post i went bak to my comp and i moved the wired mouse and it was working! i click my password which is nothing and went to the next screen of xp and then the mouse and keyboard stoped working then a window came up it said my keyboard software doesn't comply with windows and then my aim came on. then that was it
Well here is an update, when my i plug my wireless keyboard in a usb it works but when it is in ps it doesn't my mouse doesn't have the option of a usb so my mice do not work please help me so far no one has replied i know i am being pushy but this is very frustrating.
I have never used a wireless keyboard and mouse before, do they require special drivers?
If so, nuke em and let Windows reinstall.
Calm down. We'll help you.
Please, separate your thoughts with sentences and paragraphs when you post. More people will be willing to help you if you take the time to properly format your post.
he he sorry for the fast jotting down well this is another update i dont know if i said this already but only usb keyboard works not my ps2 mouse. So i was thinking maybe i should buy another mobo and swap it and if that works then i rma the mobo. What do u think? When i had booted into windows with my keyboard it reinstalled the drivers except my mouse wasn't working so i did it keyboard wise. The weird thing is that my composite mouse works until i use my usb keyboard.
Antother thing is that i used an old mouse to try the ps2 mouse and that didn't work. And yes there are drivers for wireless this is the logitech mx duo
When you say you unplugged all your wires, did that include every wire from your MB? Like the 4 pin power for example?
It almost sounds like your USB bus isn't getting enough power to run all of it's devices.
Check you bios and make sure the both that something important isn't disabled by default. It may have shut off a port you needed when you reset the BIOS.
k when i say that i unplugged all the wires i meant that all the wires in the back are unplugged. leme check bios.\
my usb devices are working properly just not my ps and ps2 devices
WOW Thank you very much u guys i was about to take this comp to fry's what happened was the bios thing the ps2 ports we disabled :rolleyes: Thank you very very much :D
lol, well, all's well that ends well! (not true in the least bit, but something nice to say :D)
