TheCoolGuy
- Jan 12, 2005
All my torrents and downloads are not getting full speeds. I keep getting the yellow smiley in Azureus that suggests I have a NAT problem because I am unable to make remote connections. I fixed this problem before by taking down all my firewalls. Right now, I have none up to my knowledge. My software one is down, Windows one is down and Router one is down. Is there some program I can use to see what is blocking ports? It is driving me crazy because I get less then 10K speeds when I am suppose to get so much more. I have Bellsouth ADSL. My line comes in to a Westell Wirespeed modem. From there, it goes into my Linsys WRT54G wirless router. My computer is directly connected to the router while the rest of the house is wireless. When I had this problem before, I turned off routing on the Westell and just make it convert the connection into the Linsys and make it a router. I did this and it was working fine until now.
Thanks for the help!
