frustrated...... need some help deciding...
umcpgrad
so I got most of my parts ready now.. for a complete system.. now just need 2 or 3 parts..
now I just need to figure out which m/b most importantly then
cpu and processor -> then heatsink a fan.. which combo is mostly the best... counting money factor too...
I have choices of..
DFI LANPARTY UT nF3 250Gb Socket 754 NVIDIA nForce3 250 ATX AMD Motherboard
for 111 dollars
or
SOLTEK SL-K8AN2E-GR Socket 754 NVIDIA nForce3 250Gb ATX AMD Motherboard for about 80 dollars...
they both got great reviews.. almost perfect... and same amount of reviews..
then
AMD Athlon 64 3000+ Newcastle Integrated into Chip FSB 512KB L2 Cache Socket 754 Processor great reviews..
for about 145ish dollars
or
AMD Athlon 64 3400+ Newcastle Integrated into Chip FSB 512KB L2 Cache Socket 754 Processor - OEM for about 180 dollars without fan/heat sink.. got great reviews but not that much... why so cheap tho??
then the later on for the heatsink/ fan
if I get the 3400+
Thermaltake VENUS 7+ Highest Performance Cooler For AMD for about 25 dollars or
THERMALRIGHT XP-90 ALUMINUM HEATPIPE HEATSINK for about 40 dollars...
is the xp-90 worth almost twice as much?? they both got great reviews btw.. and about the same amount of reviews..
any chaper 939 motherboard you recommend?? :confused: or any other good oc 939 cpu.. :)
