FrozenCPU.com's Current [H]ot|Deals!
FrozenCPU Deals
Official FrozenCPU Rep
Check out our current [H]ot|Deals!
Free Ratpadz Mouse Pad with any Hiper Power Supply!
Check back frequently!
Hi,
How does that Enermax 18 - 1 unit work with respect to the front panel I / O? Does it require the same connection as your case front panel USB and Firewire ... meaning if you use this Enermax unit, you can not use the cases front panel or is it an extra
lw3d said:
Hi,
This unit does not use internal motherboard headers, it requires external USB/Firewire Ports.
It requirest external ports to install ... from the rear of the case?
Yeah, a lot of these aftermarket I/O panels do this. It will come with a PCI bracket cover with a cutout to allow the cables to exit the case and plug into the external ports. Kinda sucks, which is why I haven't bought one yet -- I'm too lazy to mod it to use the internal headers. :)
Right, although somewhat annoying, it is nice in the sense that it can turn unused rear ports into accessible front ports. A lot more appealing when constantly using devices like MP3 players and Flash Drives than reaching around back. Definitely a nice add-on for a case previously without front ports.
if yate loon or nexus fans or the zalman fan controller or the ninja get cheaper, i will buy :)
The "PC airconditioner" looks very interesting. Summer coming up soon in Texas...may have to check this out. :cool:
+1 on the Yate Loons
While I'm at it...
TDX Water Blocks
Swiftech MCP655 Pump
(I'm assuming Mr. FrozenCPU knows that he's now fair game for begging/pleading/and badgering from the forum member ;) )
Cheers,
posterChild
Slartibartfast said:
I love Frozen CPU, great place and good service :) Hope to see some more deals soon!
QFT! I bought a Hiper Type-R from them back in August of last year!
Thanks for the deals Mr. FrozenCPU man!
Welcome to the forums FrozenCPU guy.
I love the neon sign, too.
Thanks for the deals, and I'll be looking forward to more in the future.
Just bought your Bay freezer for my SFF along with a few other sundries. Looking forward to seeing some deals. How about getting in a backpack or something that can carry (and protect) a Qpack? You'd have a line of people to buy that here at the [H].
Frozen,
Can you recommend the best available cooling fan that you have for the new Amd Opteron hestsinks [ heatpipe ]
The absolute best one ... the one that will keep the cpu coolest
and
The absolute best one that will keep the cpu coolest with less noise
Thanks ... will order when I get the information back
Wouldnt mind a deal on the stacker cross flow fan
I dont really have much to add, other than FrozenCPU is the first place I look for buying most of my PC stuff. Ive used them since they first started, and they are great. They ship the same day if you order in time, and have never messed up an order, and Ive ordered a lot from them.. They are quick to respond to emails as well. Just all around a great place to order from. And no, I am in no way affiliated with them. :)
lw3d said:
Frozen,
and
We've seen the Zalman CNPS9500 and Scythe Ninja perform quite well with Opterons. Both are quiet and perform great. As for the "best one" I'm not too sure, I would check some benchmarking results and make a decision from there.
I am referring to fan only. I like the new Amd heatpipe, I asked for a better fan recommendation
get a yate loon. only problem is that it is a sleeve bearing fan so it won't last as long as a ball bearing fan, but will be quieter. also, if it starts to die, it won't start making a whine like ball bearing fans. (all zalman cpu fans are have ball bearings because of the above). just go with a yate loon. you have enough sense to know if your cpu temps are strangely high. if you want to be a little safer but louder, go with a panaflo l1a or m1a.
Would a Delta FFB0812SHE fit and work?
What size fan do I actually need?
I'm pretty positive that those stock heatsink/fan combos are all equipt with 80mm fans.
The Delta you listed will fit, but at the same time, is also extremely loud. Not to mention its 13mm taller than the stock fan.
As for a recommended fan...
Obviously everyone wants the best "airflow to noise" ratio. We at FrozenCPU just got some new Arctic Cooling fans that have very impressive performance, and the price is right too. They use "fluid dynamic bearings" which allows 28 CFM at only 20 dBA. I'm not too sure how the fans mount to that stock heatsink, so i should note that like that Delta, this is also 13mm taller than the stock fan. Anyway, check them out:
Arctic Cooling ACF8 80mm Case Fan
If you need the fan to be the same height, the Panaflo L1A fan will do the job, and also has a great airflow to noise ratio.
I pinpointed these two fans because of your mentioned desire to find something quiet. Both fans are greatly quieter than the stock fan, but at the same time do in fact move less air. You may see a rise in temperature if you put a slower RPM (less airflow/CFM) fan in there, in place of the stock one. It all depends on just how silent you want it.
A good middle of the road fan would be the Sunon 80mm Fan - 3-pin (KD1208PTB2-6)
Hope this helps! :)
According to this site the Delta I mentioned has one of the highest cfm to noise eventhough the lists of fans on that site is not great
As long as the fan has holes for screws on the side going against the heatsink it should work. I guess the screw size would have to be the same size, about 1/16 I am guessing
Lin to new Amd heatsink - http://www.madshrimps.be/?action=getarticle&number=2&artpage=1597&articID=399
lw3d said:
Frozen,
and
I have one of these that works quiet well
http://www.frozencpu.com/fan-122.html
nice price on the keyboard
lw3d said:
What heatsink do you have it on and how much better did it cool?
Anyways the fan is way ... WAY cheaper other places :confused:
I had it on a costom laptop cooler/stand, does a good job of craming air thru the little grill
on the bottom of the laptop. this fan is a high pressure type that can maintain decent cfm
thru a High density Hs without being too noisy. I was going to put it on an amd 165 hs
but it made it way too tall to fit in a q-pack.
I'd love to mod one of those air conditioners into a drink cooler! How cool would that be :p
i'd jump my ass in on any good deals of swiftech apex water cooling kits. i'm sure others would agree too.
Hello, FrozenCPUdealguy, I was wondering if you will offer the PortCon II Airconditioning unit? since the one you have is very tempting but blocks 2 of my dvd drives.
Is there a reason the SunBeam Chameleon Color Changing QUAD LED Laser Kit - SILVER is $10 cheaper then the black version? I have a black case and want this kit, but not willing to pay $10 more for a different color...
