frosted window?
boardsportsrule
any one here have a "frosted" window?? i wanna do one and i wanna see waht it looks like..and how u did it..thanks! LMK
1500 grit sand paper and gently scrub :)
theres ur frosted window...
OR....
get a can of spray?
i dunnoo
here is whole frosted case, 1500 will clog too quickly when frosting, use 400 to really rough it up then follow with some 1500 to smooth it out.
You can buy frosted material from a plastic distributor. Look up the nearest distributor to you in the yellow pages under the heading of "plastic: sheet rod and tubing" or something very close to that. They offer different levels of frost and the 2 most popular are P-99 and P-95. The P-95 is like the case by bonzanego and the P-99 is a little clearer. If they cannot help you let me know and I will get you some. I work with plastics for a living.
Just buy some Frosted glass Spray Paint. I used some and it works great.
Just practice a little cuz it's hard to get even.
