Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Yeah. These go into the place where teh audio is: The SOUND CARD... lol.
If you don't ahve a sound card, but still hear music, you're not looking hard enough.
If it _really_ has no header, look at the back of the PC. Cut two old 3.5 mm jacks off of some speaker wire, solder the mic/spkrwires to them, stick em in the right places (green for speaker, red/pik for mike).
PS: I hae that mobo... does it say "sound" on the package? If yes Yuo=blind)
listen mate dont make me out to be a dumbass because i build pc's its just i wondered if there was an alternative thats all because my pc technicians in college said they go on the board
Those pc techs are wrong, but do this. Your case should have come with the adapter that the headers plug into, then that adapter should attach into your sound card ports on the back.
