Front USB ports causing reboots.
mcravenufo
Ravenufo's Macs
My 2 front USB ports have started causing reboots. I don't even need to plug the cable in. To cause a reboot all I need to do is touch the metal portion of the plug to the metal portion of the USB cable.
I think the only thing that has changed is I installed SP2 for XP Pro.
sounds like some incorrect or loose wirng to me. I would check your connections to make sure they're tight.
I had a similar problem except it happened when I touched my hand to the outside of my case. Turned out the power connector to the mobo was loose.
....a guess - sounds like you have a power and ground connection reversed. Touching metal takes one rail of the supply to ground, causing a re-boot. Or, the jack is loose and the Vcc (power) is shorting when you touch the "metal".
I'd double check your connections and the jack........
Good Luck - B.B.S.
Look at the physical port. Does it look different than the ones on the back? If so, the ports are broken. I had this problem with an old Gateway, the replacement motherboard they sent me had a broken USB port which caused the machine to bluescreen whenever something was plugged into it.
