Front USB Port Header?
pb_junkie
Hi, about a month ago I bought myself a new pc, I built it myself with help from my friend. We were building it because of a lan party and I needed a new pc really bad. Since he and I are lazy and didnt feel like messing with the front panel connections, such as my audio and usb headers, we just wanted to get my pc setup for the next day.
Now I really would like them to work. I got my audio to work. But I do not seem to have the right extensions for the USB port headers.
I have:
Antec Super Lanboy case
Abit AI7 mobo
the manual says, the assignments for the pins are:
1) VCC
2) VCC
3) Negative Data Channel 0
4) Negative Data Channel 1
5) Positive Data Channel 0
6) Positive Data Channel 1
7) Ground
8) Ground
9) no 9th pin
10) no connection
my extensions are:
GND
+5V
Ground
-D
+D
any ideas of where they are supposed to go?
Ok.
You want to hook +5V to VCC
GND to Ground
-D to Negative Data Channel 0
+D to Positive Data Channel 0
If you have another header, do the same thing, but use the Data Channel 1. :)
