Front USB/headphone/mic jack problem
Derekh
Im trying to connected these from my raidmax case to my Asus P4P 800 Deluxe, anyone have ANY idea where you put the lil 1 pins into? They say like, MIC1, GRND1, GRND2, USB1, ect... one set has 5, one set has 4, and another set of 1 pins has 4
Where do they go on the mobo? Read the manual and looked with a magnify glass, couldn't find anything
Derek
I had to go to my case manufacturer site to translate what was listed on the leads to what I connected to on the board. Check in the manual for the explaintion of the pin headers for usb and audio.
hmm.... my ABit mobos (both of them) had a nice drawing showing what went where -- only slight translations were needed (grd = ground, etc)
I have the same mobo and for the usb ones there should be 4 plugs for each usb port. It says it in the manual which goes where, just needs a little interpretation. Also, my case came a hole for firewire but no firewire cable, any idea how to get one? It wasnt intended to be included either
If I remember right, for each USB port there is a 5v+ a Data + and Data - and a ground. Then there's usually like a single ground that both of them share also. I had to do some interpreting to match the ones on my Antec to my motherboard. Usually have to figure out what wires are which from the case, and then which pins are which on mobo, then matching them up.
