Front Panel thingies....
mrmagoo_83
I was looking into getting one of those front panel thingies, you know with USB/FireWire, Headphones, etc...
The thing is I don't know about some of those, I currently have a Vantec Front Panel thing, the one with the annoying beep. Yea, gonna smash this thin before I get around to desoldering the speaker.
Anyway, I am looking for one that can control fans, has a few USB ports, Mic, headphones, I guess thats about it.
I was looking at the FrontX panel, but it seems to be cheap plastic door, and a little over priced.
Can anyone refer a good looking one, that is usefull and not outragously priced?
Oh, my case is blue, incase you can find one to match :D
what exactly are you talking about? is it something that will fit in a normal drive bay?
Yea, just one that will fit in a 5.25" bay. I have the Vantec Nexus, couldn't remember the name of it, not smart enough to just look down there :rolleyes:
Anyway, I am looking for something similar to it, that also has Mic/Speaker inputs, and has more than one knob, but not a cheap piece of crap, and not something expensive, just one worth its money.
i think i saw something like that made by thermaltake, ill see if i can find a link
EDIT: link found, no audio ports though.link
