front panel lights on mobo
DJ PiLLz
hey how ya doin
today i was building a new computer for my aunt and i ordered her a Intel D845HV mobo for her for the p4. it uses sd ram. she wantted to use the ram from her pervios amd system. and now i have built the computer and i am posting from this computer, and i have one problem. the front panel lights dont go on. the HD led and the power LED. i dont know if i put it on the right spot. There was a lot of things to put it on. i just put the restart switch and the power stiicw work. now does anyone have this same mobo and can me how i can do it? i looked at the manual and i dont understand shit from it.
If you don't have the LEDs connected in the right direction they won't light. If you think you have them in the right location, try plugging them in the other way around. If the board or manual has markings for positive and negative, then red or non-white will be positive on the wires to the case LEDs.
