front panel LED lights...
UrbN
I was hooking everything up onto my computer, and was about to get it started. I noticed that i had a little trouble remembering how they went in? Should the letters on the connectors be facing down, or facing up? I'm not sure which was is the ground. I read the mobo manual but didnt see how to tell the difference in the ground wire. The connectors that came with my Cooler Master case have a little arrow on each connector. I would appreciate any of your help, thanks guys.
...if they don't work, turn 'em around 180 degrees. No harm done, just no lights.....
Regards - B.B.S.
