front panel connector question
I have a 2-pin Power LED connector (going to JFP1) and a 3-pin Power LED (going to JFP2) connector. On my old mobo the 3-pin Power LED connection was unplugged, the manual for my new mobo says it goes to JFP2 along with the 4-pin Speaker connector. My question is what does the 2nd Power LED connector do? Is it just a case of either or? I currently have th e 3-pin Power LED connector unplugged. I did a quick google search but came up with nothing helpful. Thanks!
there are motherboards out there with the two pin setup, then there are some with the three pin setup.
it is "either or" so to say
you use the one your board has
