Front Panel card readers, USB, sound, etc.
kennyj449
I'm in the market for a good front-panel connector for card readers, USB ports, etc. I actually don't care about having sound and I have a dedicated fanbus for fans, but what I'm really interested in is finding one with a good built-in card reader.
Here's one example of the type of thing I'm looking for: http://www.newegg.com/Product/Product.aspx?Item=N82E16813998513
Thing is, a lot of memory card readers aren't built all that well, especially built-in ones. Many can't read 2GB SD cards, for instance, let alone SDHC cards (cards above 2GB, currently 8GB at most for most manufacturers.) A number of them also route the cables out of the back of the case, instead of making use of internal headers for USB, sound, IEEE1394, etc.
Personally I'm interested in getting one with a card reader, USB, and IEEE1394, and if the card reader is a fast one (preferably using IEEE1394) then even better. I use CF cards that run at up to 45MB/s and SD cards that run at 20MB/s, and most readers seem to do 10 on a good day.
Newegg, at least, doesn't list anything with SDHC support, and I wouldn't buy an SD reader without it nowadays. Has anyone seen a well-thought-out, modern option floating around anywhere? SDHC is well over a year old now and cards are readily available, but somehow it's still hard to find internal-style readers that support it.
I would also like to know the answer to this question and I'm posting so that I'll get an email when someone replies.
