So I'm not sure this is the best place for this thread, but as it relates to a ITX board and case I thought I'd see if any of you out there can lend a hand.
I completed an sg06 build a couple months ago using an ASRock z97e-itx/ac motherboard. Running windows 7 x64. Everything has been running perfectly and I've been very happy with it except for one nagging problem.
The front audio ports are constantly showing as having devices plugged in even though they do not. Further audio will play when I plug in headphones but it doesn't mute the rear output. My realtek audio manager does not appear to have the option available to toggle this setting.
I'm not sure if this is a realtek issue, a case hardware problem, motherboard driver/setting, or a windows problem? I have installed the latest audio drivers from ASRock and played with every setting I can find. No luck.
Thoughts?
Thoughts?
