- Dec 9, 2000
Can I use a single cable headset with FP audio? Or does it require an adapter?
Thx!
Thx!
Ty sir ordered an adapter.
Now I wonder how did you knew your Front panel audio of your case was not an integrated headphone / microphone port ?
I would imagine that it is really common for them to support both the mic and speaker at the same time.
A yes, testing on mine and I need the adapter. I thought you had a one port and wondered if it was accepting multi signal.Well, it has 2 ports, So I assume it only supports separate, also the adapter is $5 and won't be a huge blow if not needed. I don't want to take apart the case to examine the FP connectors and the manual didn't mention either way![]()
