Front mount PSU for a 3u case?
agrikk
I'm looking for a front mounted PSU for a 3U case. It needs to have the power cable and rails extending from the same side of the unit and needs to meet the ATX power spec for an Athlon XP2000+
Here's a pic:
Anyone know where I can find such a beast?
not very common, generally come bundled with cases,
most front end PSUs are modular hotswap units
and those are like a custom option, just dont show up alot in manufacturers model lines but are generally available
its basically just a different enclosure
Id inquire with Zippy
http://www.zippy.com.tw/P_PRODUCT_LIST.asp?pcp_rfnbr=3&pcp_name=PS2/PS2+ single&lv_rfnbr=2
for instance while they arent listed above
here is a PS\2-ATX front (under the 2U & Front mount PSU)
http://www.gtweb.net/j3120.html
specifically the 460 Watt PFC ATX Power Supply, Front, Zippy for $143
but there is no pic or specs so what its actually conforming to....
personally Id simply mod a supply, but thats not a likely option considering its likely work related, bosses tend to frown on that sort of thing :p
the tricky part is locating the front end model designate, there are likely several available but without those designates tough to locate
so bump it up to the manufacturers and track down the retailers
(as a note, while Ive seen them with cases, I was always curious as to the airflow direction, since most rackmounts are front to back)
Good Luck ;)
They have a single fan that pulls from the front, then exhausts the hou PSU-air into the case, where another 80mm fan blows it out the back.
I'd never actually buy a case like this, but it is work related and I basically inherited it. Frankly, I'm ready to scrap the PS case and buy a 4u case and a normal power supply. Bleh.
