Front headers?
Cuse313
I can't get my front headers to work and its really annoying have to start and restart my system from the mobo.
I have RMA'd the mobo and tried it in three different cases. Nothing seems to fix the problem. Any suggestions?
what kind of mobo? are you sure your connecting them to the right spot?
not to be a dick, but you're sure you have the wires connected the right way? I've connected the pins upside down before as it is quite easy to do.
I'd just doublecheck the manual for the pinouts on the headers... I've seen boards where the silkscreened text on the motherboard was actually opposite the header layout, so the top row was the bottom and vice versa. Just something to check.
