Front Case Fan Help
SXT14
Hi All,
I have an aspire x-dreamer 2
http://aspireusa.net/product.php?pid=87
My question is i dont know how to mount the front fans by the hard drive bays.
If any one can help me on this because i currently have 2 fans that i cant use and really would like to mount them.
Size of the fans? It looks like in the front of that case, you can fit (2) 80mm fans. I can't quite tell though. You can probably take off the front panel and mount them on that side, or they might fit better directly in front of where the hard drives go on the inside of the case. In my Sunbeam Trio, I have room for (4) 80mm fans right there, or (1) 120mm. I just put a 120mm there because of the low noise. When you mount them on the inside, it will probably be tough to get the screwdriver in there, but it can be done. It works best if you take out your mobo and hdd's.
looks like one or two 80mm's..
take off the front panel and just screw your fans in from the front with your fans on the inside of the case.
yup, i'm very used to those cases or look alike, it only takes 2x80mm fans, you need to remove the front cover, by taking of the screws, normally 6, and then put the fans inside next to the metal and screw it from the outside.
