Pwnisher said:I used a PSOne LCD (the Sony model) and modded it to use the RGB output from a video card. Turned out pretty well I think:
run tvout from your vid card in through the back of your case to the lcd. This way it is treated as a second desktop and if you use powerstrip or something you can put whatever you want on the screen.GnG said:Pwnisher : How did you get it to display that i am confused... like did you run a second vga card from your computer and tell it to display only that on the lcd? cuz i wanted to do something like that but have a video clip that would loop.. but i have no idea on how to do it... ?![]()
