Front Audio Panel on Antec P180...need help
Swede88
Lurker
Howdy
I cannot seem to get the front audio panel to work on my Antec P180 case. I've read the manual over and double checked the connections, but still nothing.
I have an Asus A8N-SLI Premium mobo with an Audigy 2 sound card. All I want to do is use my headphones. I'm not sure if this is something I've not setup correctly in the bios or windows sound options...or if my connections are not right.
Any suggestions would be appreciated
The front panel audio connectors on the case are connected to what?
The motherboard?
If so you have to enable the onboard audio solution and select it as the default audio device in windows for those jacks to function correctly.
(the front panel jacks are not going to work with the audigy unless you connect them to the audigy)
Ugh...that makes perfect sense and I even came to that logical conclusion myself a while back, but I wasn't totally sure. Thanks for the help.
you won't be able to hook up the front connections to the audigy. It uses its own proprietary connections for that.
