Front Audio Connection Help.
dhw22
Hi. I'm total newbie in regards to building my own computer but nevertheless have finished connecting everything except for the front audio. I was wondering if someone could help me match up the front audio pins from my case with the ones from the motherboard? It's probably a really dumb question but I'm not 100% sure (well except that pin 2 is GND) so any help would be appreciated.
The cables I have coming from the cases audio ports are:
MIC-BIAS
L-OUT
L-IN
R-OUT
R-IN
GND
MIC-IN
On the motherboard are the following pins (as per the manual):
Pin 1: MIC2_L
Pin 2: GND
Pin 3: MIC2_R
Pin 4: -ACZ_DET
Pin 5: Line2_R
Pin 6: FSENSE1
Pin 7: FAUOIO_JD
Pin 8: No Pin
Pin 9: LINE2_L
Pin 10: FSENSE2
Thanks.
