From miniITX to microATX
Casia
Hi
My actual setup:
- Asrock Z87 E-ITX
- Intel i5-4670
- 16GB RAM
- 3 monitors with i5-GPU via HDMI+DP+DVI
But now I need 32GB of RAM so I decided to move my build to microATX and can't find a MoBo with these specifications:
- Intel 1150 (I love my 4670)
- 1 DVI + 1 DP + 1 HDMI (or a mix of those, but no VGA)
Did you know any MoBo with these specs or are impossible?
I am sure in the near future that that type of ram is going to be in your size class but what app are you NEEDING 32GB of ram for as that type of specification is usually reserved for workstation classed machines.
Hi
My actual setup:
- Asrock Z87 E-ITX
- Intel i5-4670
- 16GB RAM
You will likely need a dedicated GPU for the video outputs. Nothing fancy really, but you will.
Many 1150 boards support up to 32 gigs of ram.
