Friends New PC Not Working Right Please Help
NebulaD
A friend of mine just purchased these parts from Newegg.com. I put it all together for him turn the pc on and everything posts like normal. On the splash screen their are white dotted lines going down the screen. I say to myself "great the video card is damaged", but when I enter bios the screen becomes normal again. So I go into bios set cd rom as first boot device and then insert the windows xp cd. I restart the computer get the annoying white lines again it goes to read the cd and says error please insert system disc. So I clean the cd try again and get the same thing. So I try my windows cd and we get the same error. So I switch out the DVD drive to my friends old cd rom drive and it reads the disc no problem. Windows loads up great with no problems, there are no white lines within windows or nothing. I think everything is ok so I leave for the night and my friend starts installing software and what not. He calls me up shortly after and tells me he tried to install the video drivers from the cd that came with the video card. He installed them and it told him to restart the pc. He restarted and now windows wont load up he said the monitor light turns orange and the screen is black. So what do you guys think we are looking at. Do you think its possible that my friend has some really bad luck and recieved both a damaged video card and a damaged dvd drive? or do you think the motherboard is bad? Any possible solution to this problem would be greatly appreciated. Below is a list of all the parts purchased for my friends new system.
  • MSI K8N Neo4-F Socket 939 NVIDIA nForce4 ATX AMD Motherboard - Retail
    Model #: K8N Neo4-F
  • eVGA 256-P2-N612-TX GeForce 7600 GTS 256MB GDDR3 PCI Express x16 Video Card - Retail
    Model #: 256-P2-N612-TX
  • Antec SmartPower 2.0 SP-500 ATX12V 500W Power Supply - Retail
    Model #: SP-500
  • AMD Athlon 64 3700+ San Diego 2.2GHz Socket 939 Processor Model ADA3700BNBOX - Retail
    Model #: ADA3700BNBOX
  • G.SKILL 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit Desktop Memory Model F1-3200PHU2-1GBZX - Retail
    Model #: F1-3200PHU2-1GBZX
  • Seagate Barracuda 7200.9 ST3120811AS 120GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
    Model #: ST3120811AS
  • NEC 18X DVD±R DVD Burner With 12X DVD-RAM Write Black E-IDE / ATAPI Model 7170A-0B - OEM
    Model #: 7170A-0B
A defective motherboard sounds more likely, but I was having nearly the same problem (sometimes my dvd drive wouldn't be detected, white vertical lines all the time, windows getting all sorts of errors trying to start up, and a window kept popping up saying my graphics card wasn't getting enough power) and it turned out my GeForce 5900 got totally jacked, AND my hard drive that was connected to a SATA card was messed up. I just unplugged that hard drive which just had a few games on it, and put a ti4200 in and my computer worked perfectly.
so you were having similar problems and all you did was replaced the video card and everything started working ok?
Yep, and also unplugged my third hard drive. I have no idea what was wrong with that, something with the jumpers, which I hate messing with and I tried everything, so I just got rid of it.
Rather than suspecting 2 failed items, I'll start by looking at single common components between them.
The most obvious is the PSU then the motherboard.
Can you try another PSU?
yes I have a psu my friend can borrow to test with. unfortunately i do not have a pci e video card to test.
