Friends building a new PC and we were trying to figure out what he wants.
Right now I was deciding on this:
MSI Neo4 Platinum , or DFI ultra - non sli NF4 Mobo.
3500+ Winchester A64 s939
1gb of memory that could OC ok, Nothing extreme, but at a good price.
X800 XL with external power connector.(if there is one with external power) What x800 XL do you recommend. For under $350 ish.
Decently priced power supply with a PCIe and atx 24 pin power connector.
Case and HD's should be easy enough to decide. probably 200gb SATA Segates with NCQ.
Dual Layer dvd burner. (any recommendations on this?) They all seem to be rather cheap but I don't know which is recommended. http://www.newegg.com/app/SearchProductResult.asp?DEPA=0
and a Thermalright xp-90 HS with 92mm Panaflow High Output on it.
SUGESTIONS?
SUGESTIONS?
