SamuraiInBlack
- Oct 10, 2003
Specs are as follows:
AMD Athlon 64 FX60 1GHz FSB Socket 939 Dual Core Processor
Lian Li PC-7 B Plus Black Aluminum ATX Mid Tower Computer Case
LITE-ON Black ATAPI/E-IDE DVD Burner Model SHW-160P6S
CORSAIR XMS 2GB (2 x 1GB) 184-Pin DDR SDRAM Dual Channel Kit System Memory
Two Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drives- OEM
eVGA Geforce 7800GT 256-P2-N515-AX Video Card (PCI Express)
ASUS A8N32-SLI Deluxe Socket 939 NVIDIA nForce4 SLI X16 ATX AMD Motherboard
SeaSonic S12-600 600W Power Supply
Creative Sound Blaster Audigy2 ZS 70SB035000000 8 (7.1) Channels 24-bit 192KHz PCI Interface Sound Card
Thermalright SI-120 heatsink with 120mm fan (Panaflo, I think)
This is his first time building. Problem is there is no POST beep after powering on. All fans power on, there's a light on the board that is on, the hard drives spin up and seem to try and access something. After I resisted the urge to figure out a way to reach through my monitor, and smack him back to the 2nd grade on his end of the Internet, for comparing its noise levels to a Dell ("The Dell was quieter!"
) I decided to try and help him as best I can.
Everything he says is seated properly. But despite this, no POST beep, no video, no kickover. From past experience I'm thinking dead processor, which I hope to god is not the case.
I'm also thinking the board needs a BIOS update since it's an FX-60 but I'm not sure how relatively new the board is. But I'm not sure if that would be a simple enough cure. Obviously at this point the only way to find out is to get another 939 processor, possibly a non-FX one that isn't too extremely new to find out if it boots off of that. Problem - he doesn't have one. Has made it very clear he isn't going to buy another one. Probably won't ship out his board and graphics card to me to see if I can pop mine in and get it to work. Don't blame him.
I was thinking maybe having him pull the CMOS battery and clearing it that way and popping it back in just to see what happens. But I don't know how helpful that'd be.
Any ideas? And yes, before anyone asks, he RTFM'ed on everything.
