Friend's Budget Build
Tunnel Vision
My friend (who mostly plays WoW) wants to build a gaming rig, but he's on a strict budget (<600$). So far, I've come up with these parts to buy from newegg.
Case: Gigabyte GZ-X3BPD-500 38
CPU: Intel Pentium E5200 70
GPU: HIS 4830 512MB 93
Mobo: Gigabyte GA-EP45-UD3L 90
RAM: Corsiar XMS2 2x1GB DDR2 800 36
PSU: Corsair 400CX 50
HDD: WD Caviar 250GB 50
ODD: Samsung SH-S223F 22x DvD Burner 28
OS: Windows Vista OEM 100
As of 7/14, the total comes out to 555. Not including any possible rebates.
I'm sure most of these parts will work well together, but I wanted to post here to make sure it's a good build. I guess what I'm most concerned about now is ram compatibility with the gigabyte mobo. Also, he wants to get a new 19' or 22' widescreen monitor, what low price monitors do you recommend?
Not a bad build. However, an AMD build is your best way to go for the money. Consider this build
CASE/PSU - Antec 300 + Antec EA430 for $84.94
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.213672
CPU/MOBO - AMD Phenom II X2 550 3.1ghz + ASUS M4A78 both for $169.98 ($10 MIR)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.211674
RAM/VIDEO CARD - OCZ Vista 4GB DDR2 800 + Sapphire Radeon HD 4850 both for $134.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.210799
OS/HDD - Windows Vista Home Premium 64 bit + WD6401AALS 640GB both for $179.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.205082.22-136-319
OPTICAL - LG 22X Sata DVD Burner for $27.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136168
Total: $597.87 before shipping
Old ass monitor meaning, before they started massively bullshitting about the specs.
Also my monitor. I tried using a Samsung 24" TN panel but it looked noticeably worse in comparison.
When I'm playing games I want them to look good. If you play singleplayer games it is important that they look and sound good. If you only play multiplayer games for the competition it doesn't matter that much how they look or sound.
Thanks for all the input guys, it really is appreciated. I think we're going to get the 19' Hanns-G monitor, it seems like it would fit his build the best. Also, I'm really going to think about getting an AMD build. I haven't built an amd rig since 2004, so this will be a nice time to try a phenom build.
